How do I detect folder with the same name on difference drive
Hi, I’m new at this.
But I have multiple folder with the same name on multiple drive.
Is there a way to detect and compare them?
Right now, I’m doing it manually side by side, which is exhausting.
My goal is to relocate some file from differrence drive, but the same folder name, and group them.
It need to be decide by me ultimately, but after 4 drive of comparison, I just can’t LOL
Thank you in advanced.
These tools can help:
Hi, thank you for answering.
However, I did already find these two tools, but it still doesn’t help with my solution.
While synchronize is automaticallt kind of duplicate two folder, but I didn’t want to have duplicated files on difference drive.
Both drive have the same folder name, but it contents is difference.
And Finding duplicated also couldn’t detect folder name, only the files it contains.
But pehaps I couldn’t know and understand all the fully funtion of them though.
If I being more detail, let say my drive D and E has the same file structure.
Project:
  • months
    • dates
      - locations
I want to detects either date or location from difference drives. Then I could decide which files inside should contain together in each drive.
It wouldn’t be a problem if there is 2 or 3 drive.
But there are at least 8 external drives now.
I see...
You are on drive D: and have located the folder 'Date-XYZ.' Are you trying to determine if and where other 'Date-XYZ' folders exist on drives E: to M:?
