Hi,
I want the exact same layout as explorer's downloads folder (the default view). Meaning the files are grouped by day, and in that grouping from oldest to newest.
Is that possible with Opus? And if so, how?
Thanks.
Hi,
Thanks.
Right-click the Modified column and choose the Group By option.
Use Folder > Folder Options > Save if you want to then save the format for that folder.
Thanks for your reply Leo!
Btw, I am a happily registered Opus user, I just want to keep anonymity on the forums
Linking your account won't tell anyone else who you are.
