I used the grab handle on a toolbar and hosed their layout and can't figure out how to unhose it with the grab handles. I did get it back by turning toolbars off and on until they were arranged the way I want but I'd already typed most of this and I think there has to be a way to do this without the toggle on/off that I stumbled on.
I have the Menu, Operations, and Favorites toolbars enabled and they're stacked in that order.
When it was hosed I ended up with the Menu and Operations on the same line and Favorites docked to one side of the window. Sometimes when I moved them the Menu and Operations will stack (each on it's own row) like they used to but they wouldn't do it consistently and if I tried to drag the favorites back up it would move Operations to the same line as Menu.
Is there an easier way to arrange the toolbars?
thank you
