How indicated capacity on drives
Hello, can we add next to the readers (in red) their capacity used
THANKS
Sans titre opus
Yes.
Set COLUMNSTOGGLE="sh:usedspace(!,a,0)"
You can add it like any other column.
Thank you Leo for your response so quickly...but I must explain myself badly, I would like to do this manipulation (if possible) on the "order" shortcuts under "personalize" see attached photo..Thank you
AFAIK you can't show it on the toolbar/menu drive lists, only in the This PC folder.
Thank you for the reponse .... :slight_smile:
@Leo
Could the OP's request be added as a new argument to Go DRIVEBUTTONS?
