How to Append and Truncate in Bulk Rename function?
How to Append and Truncate specific amount of characters to/from the beginning/end of the file names with Bulk Rename function?
In the rename dialog, make sure "use preview list to build macros" is on.
Then click the a name in the New Name column under that, and start editing. Edits will be applied to all names at once.
Double-tap the Home or End key to align all the names to the left or right (e.g. before prefixing or appending).
Thank you Leo for your timely and accurate reply.
