How to become 4 columns?
just like the picture,how to make 2columns to 4columns?
:smiley:
The only way to have more than two folders visible at the same time is to open two or more windows. Each window can only display one or two folders (with others in folder tabs, of course, but not all displayed at once).
thanks for your answer,leo.i think this function is very useful。can we add this with script or oher way(sorry,i do not konw more about programme...)?
PS:i am a chinese user,we all think do is awesome.we benefit a lot from it.however,you know the shortage of introduction or。。。usage gives us
limitations of going deep into this “hand”。
so,i hope more “leos” can do more for it。
Best regards。
Scripts can open windows, yes.
What do you want a script to do exactly?
[quote="leo"]Scripts can open windows, yes.
What do you want a script to do exactly?[/quote]
I mean,i just want to achive 4columns,no matter scripts or any way。 Just this。。。 :thumbsup:
The only way to do it is to open two windows a put them next to each other.
There are lots of ways to open two or more windows. The best way will depend on the details of what you're doing.
