I have a home network of 6 computers. Thought it would be nice to have Opus9 settings all the same on all the computers. Tried "BAckup & Restore", copied the resulting Opus Config.ocb file to another computer and did a restore there.
One problem is 3 computers are Vista and 3 are Windows XP. The path for the default lister needs to be different.
Other problem is I have some customized buttons with customized icons. I can copy those icon files over, but need to set the path to the icons for each button.
Is there a quick way to do this so I don't have to do all the setup manually by hand for each of the 6 computers?
Since I'm still playing with Opus9, continuing to customize it, it needs to be quick and easy for me to export new changes to the other computers; otherwise I'm less likely to do it. (Maybe I could get AutoHotKey to do it?)
