Just downloaded the 9.1 trial version and tried to customize to to get display colors I would be happy with. Dozens of color choices can be made, but one I can't figure out is the background color used on the column that is chosen as the sort column. Right now it seems to be white which is dramatically different from my chosen File Background Display and it clashes horrendously. Is there no way to change this? If so, that would be strange as it covers quite a bit of screen real estate. All you have to have is one missing choice and you might as well not have any, since you still can't get the scheme that you want.
Any ideas?
Thanks
~Paul
