I have a dual monitor setup and I would like to set DO to open in a specific location on my second monitor. Is that option possible within DO? DisplayFusion currently does this but it's not seamless.
I'm pretty sure if you save a Lister Layout while the lister is on the monitor you prefer, it will store the location with the monitor specified.
After positioning the lister where you want it (including the monitor you want it on):
Settings -> Lister Layouts -> Save this Lister
Also, if this is your Default lister layout, make sure this is not turned on:
Preferences / Launching Opus / Default Lister / In a fixed position relative to the monitor the mouse is on
Thank you so much. It worked perfectly.
There are also options to control which monitor the Default Lister opens on, under Preferences / Launching Opus / Default Lister.
