How to display a column showing Protected status
Hello,
When using WE, if you hover over a WMA file, one of the tags that's displayed is whether or not a file is DRM protected (it shows Protected: Yes|No). Is there a way of displaying that same information in Opus? I would like to show a Flat view of files (no folders) and be able to sort by that info. Thanks!
We will add this in the next version.
Thanks for the quick reply!
