Hi,
I have installed Dropbox Folder sync:
wiki.dropbox.com/DropboxAddons/DropboxFolderSync
...that should enable me to right-click on a file and have it sync with Dropbox. However that option doesn't appear when I right-click in Dopus. I can confirm that 'Hide windows items on file context menus' in Preferences is unchecked
Thanks Patrick
It looks like DropboxFolderSync is a 32-bit shell extension, which you can't use with 64-bit Opus (or 64-bit Windows Explorer, for that matter).
If I were to install 32 Bit Dopus would it work then? Is there any downside to using 32Bit Dopus vs 64 Bit?
You can't install the 32 bit version of Opus on a 64-bit system unfortunately.
