How to exit DO?
I forgot....
When closing DO --
When I click the 'X' in the upper right corner of the program, the DO icon resides in the tray.
What do I need to do to exit the program completely and NOT have the DO icon reside in the tray?
Thanks.
Right-click the tray icon and selected Exit.
There is an Exit Program item in the default tray-icon menu. You can also add the same item to any toolbar or menu or hotkey that you like.
Additionally, in Opus 9, there's an option in Preferences that tells Opus to exit automatically when no listers are open, if you don't want Opus to run in the background.
[quote="nudel"]There is an Exit Program item in the default tray-icon menu. You can also add the same item to any toolbar or menu or hotkey that you like.
Additionally, in Opus 9, there's an option in Preferences that tells Opus to exit automatically when no listers are open, if you don't want Opus to run in the background.[/quote]
That did it. I registered the program yesterday and love it! What a great forum....speedy solutions and [mostly] knowledgeable members.
Thanks.
