How to filter by rating?
I know how to use setattr META "Rating:4" to assign star ratings to files but I can't see how to define a filter that will use Rating as a means of limiting what is shown. Is there a way? I'd like to rate a bunch of photographs and then filter down to the best ones.
Regards, AB
Hmmm
I thought this had been raised before. See here. It would be neater if Opus filters supported the Rating keyword but at least there is a way....
Regards, AB
I have revisited this requirement and have come to the conclusion than it's best done by filtering to a collection.
This can easily be fully automated with a button. In my case I have set up LMB to add to a collection and RMB to clear, then add.
LMB Code : Find NAME #Stars IN {s} FILTER SHOWRESULTS tab COLLNAME Starred CLEAR=No
RMB Code : Find NAME #Stars IN {s} FILTER SHOWRESULTS tab COLLNAME Starred CLEAR
If you want to be able to tweak the named filter before executing, just add the NOAUTORUN argument.
LMB Code : Find NAME #Stars IN {s} FILTER SHOWRESULTS tab COLLNAME Starred NOAUTORUN CLEAR=No
Regards, AB
