I am brand new with Opus and very frustrated. I am so mad that i cannot find out how to get just a simple default Lister. I have attached a Picture showing what I would like and then what my Lister looks like that I hate. I hate it because everthing in the left side I want to open up on the right but it opens up flat I guess in the same pane. Please help me get a Lister like the pink one and I will be so happy. I cant seem to delete the lister I created, I have tried and tried but it remains the same. Thank you Please. Tim
Open up the Lister menu:
Turn off Dual Display, and turn on Folder Tree.
To save that as your new default, use Settings > Set As Default Lister.
THANK YOU but i still cant get it to work like explorer, when i clik on a folder everything opens up in same pane, i would like it to opetn the folder in the 2nd pane
It doesn't look like you did what I said. The screenshot shows Dual Display is on and Folder Tree is off, the same as before.
It's always "cool" seeing DO-screenshots containing warez!
