How to Go to Top of Lister
Hello,
I'm using a button with the function Prefs LAYOUT="Current TV Programs" and want it to jump to the top of the lister. Currently it opens up with the 212th line selected, a number that seems to increase over time. How can I get it to open at the top?
I use the following 3-way button:
<?xml version="1.0"?>
<button backcol="none" display="icon" textcol="none" type="three_button">
	<icon1>C:\Users\Chuck\Documents\DOpus\Themes\CCleanerish\Icons\Go_To_Top_32-22x22.png,0</icon1>
		<label>Go to First Row</label>
		<icon1>#newcommand</icon1>
		<function type="normal">
			<instruction>Select FIRST</instruction>
			<instruction>Select SHOWFOCUS</instruction>
		</function>
	</button>
		<label>Go to Last Row</label>
			<instruction>Select LAST</instruction>
		</function>
	</button>
</button>
You could pull the code from that, I think.
When I ran it this morning it opened up at the 224th file. I've discovered that it always opens at the file modified on 1/23/2017. Because each day newer files are added to the list, that file is increasingly further down the list.
To describe all I want to do, in effect, is for it to hit the Home key after it loads. When I run it now and physically hit the Home key I get the desired results. I'd just like it to load that way automatically.
