It sounds like a newbie question, most probably it is.
If at all possible, I'd like to accomplish the following:
Explorer view, select 2 subfolders (in right window panel)
say:
D:\Folder1
D:\Folder2
Then... what action to take...(?)
in order to:
- view the contents of both folders in Dual Display mode (within the same Opus session)
- switch between images and explorer for both folders
this to compare/update the images in the folders more easily.
I believe F6 will only get a 2nd window pane of the existing window pane, i.e. not the subfolders.
