How to import a preset script?
Trying to import the titlecase preset but not succeeding
tried this:
  1. open advance rename
  2. select script mode
  3. create new reset and name it title case
  4. File -> import rename preset select TitleCase.orp
  5. script is imported and Standard Rename is selected
When I click on title case default rename script is inside
What is the obvious mistake?
thanks...
I think you did the import and save in the wrong order. This should work:
  2. File -> import rename preset select TitleCase.orp
  3. create new preset and name it title case
Step 2 configures the window according to the .orp you import. Step 3 then saves the window's settings as preset into your list.
thanks!
