How to keep columns fixed width?
I know it is possible to keep (say) long file names from pushing (say) date, size, etc. columns to the right, out of sight. But I can't find the setting no matter how carefully I (think) I look.
Once some kind soul shows me how to set that, then I need to know how to save that in my lister--I (think) I know how to save lister layouts but none of the settings I make ever get saved.
A second example of settings I can't seem to save is the order of the columns--e.g., file name then date accessed then size, etc.
If you don't mind, may I also ask how to sort file names mixed with folder names? I used to know where that setting was and now I can't find it.
Thank you,
Doug
Which version of Opus are you using?
