How to keep extension when creating shortcut?
When I create a shortcut for a file, I only see .lnk, and the original extension is not there.
I find having the extension useful, so like .exe.lnk, .txt.lnk.
Any way I can configure this, please?
This command will make shortcuts to any selected items, putting them in the same place as the items:
Copy HERE MAKELINK PATTERN * AS *.lnk
Removing HERE makes the shortcuts in the destination folder instead, if you want that (use this if you want to create shortcuts via drag & drop):
Copy MAKELINK PATTERN * AS *.lnk
If you need help with how to set up either command, let me know which method of creating shortcuts you use and want to focus on.
Hi Leo,
I saw this command earlier when I was searching the forum, but I thought that was talking about something else.
I'm not sure how to use the command, if you can please point in the right direction.
I just use two basic ways to create shortcuts:
  1. Right-click -> create shortcut in current directory
  2. Drag folder/file to destination folder -> choose to create shortcut
Thanks for helping me on this
Both are done via Settings > File Types > All Files and Folders. Once there, here's how to add each thing:
  1. On the Context Menu tab, create a new item. set Type to Run an Opus function, and use this as the command:
  2. On the Drop Menu tab, create a new item (or edit the existing Create Shortcut(s) Here if you want to replace it), set the type as and use this as the command:
thought i'd add onto this instead of making a new post... i followed this guide here: Disable the '- Shortcut' Text Addition for Shortcuts in Windows 11 (winaero.com), which suggests adding an entry in HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\NamingTemplates.
That works fine on my Desktop and in Windows Explorer but not in Directory Opus. If i uncheck the "Use template when creating shortcuts" option in Settings>File Operations>Options, Directory Opus will remove the shortcut text (was that because of my registry edit?), but also removes the extension, as the OP mentions. Is that expected?
All that to say, I tried to look around in Settings but i couldn't find " File Types > All Files and Folders " nor the Context/Drop menu's mentioned, so I have no idea where to put in the commands mentioned.
Any help appreciated!
Oh, sorry, I (incorrectly) assumed Settings meant Preferences and just glossed right over that. After playing around with this a bit, I can't seem to replicate my preferred method of creating shortcuts, which is by selecting a file, then pressing Control+C to copy, then right clicking in the destination and choosing "Paste Shortcut". Is there a way to do that?
Out of curiosity, why does Directory Opus not just follow what Windows does when unchecking the "Use template when creating shortcuts" option?
Thanks for your help!
There's an option in Preferences to control the shortcut name, use the search field to find it by searching for "shortcut".
Enter this as the shortcut template in Preferences / File Operations / Options, if you want the shortcuts to include the original files' extensions:
=if (count==0) return name+ext; return name+ext+" ("+count+")";
More detail here: Generated File Names [Directory Opus Manual]
i reverted the changes made in File Types>All Files and Folders, and applied your template and it works perfectly in all use cases! i think this is a much cleaner solution to the original post :slight_smile: thank you so much!
