How to keep selected and active file sinchronized on rename
Hello.
I cannot manage to solve an annoying configuration issue on 9.0.0.9.
I configured the lister to immediately sort files after a quick rename (F2 key), wich is what i want.
My wish is that the renamed file (the initially selected one) once renamed and moved to the right sorting position keeps selection and activation.
What I get instead is that the renamed/sorted file keeps selection (dark filename background) but the actual active file becomes the one that replaces the renamed file in the original position (dotted border).
So, when I want to move the selection with cursor keys, instead of the desired selection, the active file becomes selected and I get this annoying result.
Is it possible to configure DOpus in such way?
Thanks for your attention... Umberto
Currently I don't believe there is any way to do this, sorry.
