How to maintain selection state in destination lister?
After files are copied over to the target lister, how can the selection state be kept, so they´d remain selected in the target as well? "nodeselect" will only keep the files selected in the source. :frowning:
thx!
You could try adding the Select SOURCETODEST command to the function following the Copy command.
Hi, Jon
thank you very much!
one thing, how would that work using the same drive? For example along with the "copy MOVEWHENSAME" command?
It won't work if you move the files. (At least, it didn't when I did a quick test a moment ago.)
Hi Leo, thx for the quick reply. Hmm, well, then maybe it´s worth to consider to include this ability? It basically doesn´t seem to be that much difference between copy & move in that regard.
