I have 2 rename presets setup; as far as I can tell, they're called exactly the same, but one is via a toolbar button, 1 by the context menu. The button call does not show the rename dialog, it just does the rename (which is what I want).
The context menu call always brings up the rename dialog window when I click it, requiring a second click on the OK button, instead of just renaming automatically?
Here's a screenshot of both settings, where am I screwing up?
