Hi, I have multiple external drives connected to my PC, and a Directory Opus window opens for each one when connected, or in the event of a momentary disconnect, upon reconnecting. Is there a way I can prevent these windows from automatically opening? Thank you.
If you want it so nothing happens at all, that is a Windows setting, not an Opus setting. In Windows 10, type "autoplay" into the start menu to find it:
Or, if you want a new tab instead of a new window, go to Opus and turn on Preferences / Launching Opus / Explorer Replacement / Open external folders in a new tab.
