Hello, I'm working with Vista... It seems no possible to print just the names from a repertory ? it's a bug of french version ? thanks for help...
The Print Folder dialog has a Flat View checkbox. (Not sure what it's called in the French version.) Turn that off and it will only print the directory and not go into the subdirectories.
Hi Leo, thanks without flat it's ok...have a good day...
