Hi everyone,
I have an Excel workbook with a password-protected VBA project, but I have forgotten the password. Unfortunately, I do not have an unprotected copy or backup of the file.
I need to access the VBA code to make some changes to the existing macros. I can open the Excel workbook and use its worksheets, but I cannot view or edit the VBA project because it is password-protected.
I have tried checking the workbook settings, but I have not found a way to recover the password.
Has anyone faced this problem before? Is there a reliable way to recover or remove a VBA project password without a backup file?
Any suggestions or practical solutions would be helpful.
Thanks in advance!
You'll need a password-recovery tool such as Advanced Office Password Recovery.
The free trial may be sufficient if the workbook uses older, weaker protection or the password is short.
You could use passfab (paid software)
