How to remove Bilinear on Pictures display
hi all, i'm back with some questions that i still have....hum!
As a Pixel Graphic Artist i need to see our nice Square zoomed, so how can i remove the bilinear when i show pictures ?
If you turn off Preferences - Lister Display Modes - Thumbnails Mode: High quality image scaling then it also affects the image viewer, for most image formats. You get nearest neighbour scaling by the look of it.
(GIF images will still get bilinear scaling unless you disable the Animated GIF plugin, since the plugin ignores the thumbnail scaling quality setting.)
((Of course, your thumbnails (at least the ones that aren't already cached) may be a little uglier after enabling the option,))
ARf, of course it's not possible to affect just the viewer and not the thumbsnails display in lister ? i think it will be easy to add this features in the viewer prefs,no ?
Anyway thanks nudel
Not at the moment. You could request it if you want.
oki Nudel, it's done...(^.~)
Directory Opus v9.1 new release appeared, nothing changed :cry:
Sending an official report to GPSoftware does not automatically mean they'll drop everything and implement your request. Feature requests and bug reports are prioritised and it can often take a number of releases before your own issues are addressed. Impatience certainly won't help.
