# How to save column configruation-width and column selection
**URL:** https://resource.dopus.com/t/how-to-save-column-configruation-width-and-column-selection/9012
**Category:** Help & Support
**Created:** [January 2, 2010, 8:23am UTC](https://resource.dopus.com/t/how-to-save-column-configruation-width-and-column-selection/9012 "2010-01-02T08:23:56Z")
**Posts on this page:** 2
**Page:** 1
<div class="post-metadata">
### Author: ![Alterego](https://resource.dopus.com/user_avatar/resource.dopus.com/alterego/32/26910_2.png) [@Alterego](https://resource.dopus.com/u/Alterego)
#### Post date: [January 2, 2010, 8:23am UTC](https://resource.dopus.com/t/how-to-save-column-configruation-width-and-column-selection/9012/1 "2010-01-02T08:23:56Z")
</div>
Hello,
Whats the most easy and practical way to save the column widths and selected number of columns for a particular drive / folder / lister display.
For example I always use the Dual Vertical Display mode with dual folder trees. I set the column widths on both sides according to my requirements and then select a 'File Count' column in the right folder display only and the "save" it.
However whenever I exit and restart the program, the column widths are set to original or default settings and the selected columns on one or either side are missing too.
I am little confused in getting to understand the appropriate way it handles the specific views on either sides. Is it folder display or styles or content type or lister display modes. There is a plethora of grainy controls inside preferences which make it all more confusing to understand a simple desired solution,
Any guidance would be appreciated.
Thanks.
### Author: ![Leo](https://resource.dopus.com/user_avatar/resource.dopus.com/leo/32/69732_2.png) [@Leo](https://resource.dopus.com/u/Leo)
#### Post date: [January 2, 2010, 8:31am UTC](https://resource.dopus.com/t/how-to-save-column-configruation-width-and-column-selection/9012/2 "2010-01-02T08:31:51Z")
</div>
Check out the [Folder Formats FAQ](https://resource.dopus.com/t/folder-formats-quick-guide/1313/1).
