How to show CRC32 column in uppercase?
Or how to create an avaluator column that uppercases the CRC32? I tried searching the evaluator documentation and even tried something like
return opus7zip:crc.toUpperCase();
with no luck
with no luck
Thanks. It worked!
Solution:
return UCase(crc32sum);
