How do I tell for sure that Opus is done copying, without clicking through every lister?
It seems the copy operation progress bar, once it is minimized to a small icon above the statusbar in one lister, does not appear on all listers.
Due to this, I frequently find myself guessing, is Opus done copying or not? To make sure, I bring every single lister to the front, and look for the little copy-progress icon above the statusbar.
Is there some clear obvious indicator "All Copy operations Finished" or some such, so I can be sure that I can remove USB sticks etc.
BTW: Thanks for the awesome support and updates. I bought the Opus 12 update such a long time ago, and all these hundreds of updates have been free since then. So many things have been improved! My body and wallet are ready for Opus 13
