bytim
1
Run this, all is OK
copy {filepath$} FILTERDEF size match >= 1 mb
When using {dlgstringS} to get a value, This code doesn't work as expected:
@set size="{dlgstringS||1}"
copy {filepath$} FILTERDEF size match >= {$size} mb
Is there a solution? if not use a script.
Leo
2
I think a script would be needed, as the filter definition can't use {...} codes.
That would also let you do some input validation to ensure only a number is being inserted.
BTW, you don't need to specify {filepath$}
as the selection will be copied by default.
lxp
3
I think it's more of an execution order problem. This seems to work:
Copy FILTERDEF size match >= {dlgstringS||1} mb
Leo
4
That didn't work with the {filepath$}
still there, so I figured it didn't work in general, but you're right, it seems good so far.
bytim
5
First,{dlgstringS} will popup a window for every selected file.
lxp
6
You need to remove {filepath$}
bytim
7
all OK now!
thank you all!
I use a script to get relative pathdepth.
function OnAddColumns(addColData) {
var col = addColData.AddColumn();
col.name = 'RelPathDepth';
col.method = 'OnRelPathDepth';
col.justify = 'right';
col.type = 'number';
col.label = "PathDepth(Relative)"
function OnRelPathDepth(scriptColData) {
var relDepth = scriptColData.item.path.components - DOpus.Listers.lastactive.activetab.path.components;
scriptColData.value = relDepth<0 ? 0: relDepth;
and use script column like this:
copy FILTERDEF type match group 图片 and script match PathDepth/RelPathDepth = {dlgstringS||1}
