Hello there at Directory OPUS
I have no or menus or toolbars showing except the one that starts with “ROTATE” at the left. I can’t initiate anything! It is displaying a directory and files therein, but I can’t do anything else. The question is “is there a hidden key sequence or command or something that can provide a minimally usable program displayed, like with the menus”? After that I can alter it in some other way. I’m currently using version 11.19 and 64bit on Windows 10.
Image follows:
I have even tried to reinstall the program to possibly get the basic version to use. Does not change the conditions at all.
BTW: I have used the program for several years and love it, except for being able to get into this circumstance, wish there was at least a way to keep the menus as a minimum configuration.
Thanks very much.
Roger J Olfert
