.icl Viewer
Is there a plugin viewer to display .icl files?
The viewer will display the technical file information, but will not preview the iamges in the icon library.
There isn't one at the moment.
For now you can view them in the Select Icon dialog which is used to change icons when customizing a button.
Not elegant - but at least it's a way to view the contents.
