lblb
August 21, 2017, 8:19pm
#1
There is a setting in the preferences:
Which should ignore the given prefix(es?) when sorting. However, when enabled this doesn't work for me as expected.
Turned off:
Turned on:
So in essence it doesn't do its job, it only moves all elements with the "The" to the top.
What I expected—and I presume what most would consider the correct way—is the order
A
The A
Z
The Z
Please fix this. I'm on DO 12.6 Pro. Maybe another setting could be whether the "A" or the "The A" is placed as the first.
Are you putting a space after 'The' - like so 'The ' in the global filters preferences?
lblb
August 22, 2017, 6:20am
#3
No, there is no space after "The". I tried it with "Test", same behaviour as with "The". I tried "A", now it works correctly.
Jon
August 22, 2017, 7:22am
#4
If you don't include the space then only the "The" is being ignored, which means the names are sorted beginning at the space. Since spaces sort before letters, you get " A" and " Z" followed by "A" and "Z".
lblb
August 22, 2017, 7:28am
#5
Thanks. I assumed the setting would include the space automatically and just consider full words.
