Image Viewer: metadata pane ignores Text color setting
The text color setting is obeyed by the regular metadata pane, but not by the metadata pane in the viewer, as you can see here (the text is black instead of yellow).
Work fine here
Tried changing the settings in case that was a hang-up from carrying old settings, but still no luck.
The metadata pane shown is from within the Image Viewer. The lister's metadata pane correctly uses white text.
Win10x64, DO12 Beta 9.
[quote="playful"]The metadata pane shown is from within the Image Viewer. The lister's metadata pane correctly uses white text.
Win10x64, DO12 Beta 9.[/quote]
I confirm, text color not apply in meta panel viewer.
Not that pane is not refresh when you change background color then Apply Prefs window.
This will be fixed in 12.0.11 beta.
