Image viewer not reading color profiles
Hi there, as a photographer most of my Jpeg files are exported with either an srgb or ProPhoto ICC profile embedded in the file. It seems like the directory opus viewer does not read the embedded profile in the files like for example microsoft edge or other image viewers. The result is over saturated colors. Is this an option that can be turned on somewhere? Reading ICC profiles embedded in images has been fairly standard for a while so I'm wondering...
Try changing the Preferences / Miscellaneous / Advanced: [Image Formats] use_color_management option.
Great, this worked. It was pointing to my screen profile directly, while switching it to "Primary Display" fixes the issue.
