In the DOpus image viewer you can (optionally) scroll through the images with the scroll wheel. That works here as expected. But when I click on menu->edit->copy to (or similar) and save the file somewhere the scrolling doesn't work anymore. I still can go forwards and back with page-up/down buttons or the buttons in the toolbar.
Please confirm that this is not a bug on my computer
If I switch to another application (e.g. a webbrowser to write down this) and then switch back to the image viewer I can scroll with the mouse wheel again.
What's even more interesting: If a file with the same filename exists in the directory and the rename/replace dialog is opened than the problem doesn't occur.
Unfortunately they didn't fix that in the last update. (9.1.1.8)
Am I the only one who find that annoying?
Perhaps I should change my workflow.. thinking about tagging the pictures and then copy the checked ones at once to the destination. But what if I would like to copy them to different locations?
If they waited until the to-do list was finished for each update there wouldn't be another update until 2015. Drop them a note if you want to remind them, but the error is definitely on the list.
If I'm organising images into multiple destinations then I usually use the viewer pane instead of the standalone viewer. That only works if you don't need to see every image full-screen, of course, so it may not be a good replacement for your current method.
You can make a button which always asks you for the destination to copy/move to, even if there are other file displays open which, normally, would automatically be selected as the destination. e.g.
