i have one question. few days ago, i must reinstall windows. and, with all, also dopus. everything seems to work good, but i lost one detail, for me really usefull. before, when i lay cursor at image file (jpg, bmp...) in little baloon widow, beside informations about image, i use to have little thumb-preview of image. but now i lost it. so, is that something in prefs or what. please, can somebody tell me how to enable this!
You have to change the File Types. Either adjust the File Type Group for "Images" or the individual file type .bmp, .jpg, etc. In the "Edit... File Type" dialog is a tab for InfoTip. Enter the command for {Thumbnail} there.
THANK YOU!!! that is that!! but, now i'm not sure how i did it before, because this is first time that i changed something in general file typs.
but.... it's working!!
thanks once more!
Sorry, i meant specifying a size in the {thumbnail} tag for the infotip
for example something like that {thumbnail w96:h96} or such a thing (to be able to vary sizes depending of the place where the tag {thumbnail} is used
DOpus is the king of customized things, maybe this very special thing can exist
DOpus is the king of customized things, maybe this very special thing can exist [/quote]
Hallo, the thumbnail size is always the same as in lister modes -> miniature modes, though i´d also appreciate it if it could be set independently (preview in the lister vs tooltip thumbnail size).
