Hi,
I recently noticed some inconsisten behaviour when clearing a applied filter.
I have the filterbar active all the time without a activation key. I'm using Dopus version 11.50.
When i type an entry in the filterbar input box the filter is applied. When I press ESC or the clear filter button, the filter is removed.
If I do not type the text in the filterbar input field but start typing, the filter is aplied correct, however when I press ESC all but the first character is cleared from the input field. So you always have to press ESC twice to completely clear it.
It is not a big problem, but when you want to restore the filter it does not work correctly and you have to type it again.
