Is it default the shortcut of DOpus differ from Explorer?
Hello, I'm a recent newcomer to DOpus.
I enjoyed setting up the various options, but when it came time to use them, I found that basic shortcuts like Ctrl+C, Ctrl+V, and Ctrl+A didn't work.
So I went into the relevant menus, and sure enough, the shortcut combinations looked different than what I knew.
I'd like to know if these are the defaults and if there is a way to bulk change them to the Explorer ones.
Thanks in advance.
Yes, they are.
Thanks to your reply, now I've figured out what's gone wrong.
I had unknowingly deleted default buttons from the standard toolbars, so the shortcuts that were assigned to them had been deleted as well.
After resetting those toolbars, the shortcuts work fine now.
I guess I did something a little stupid.
Thanks for the answer!
