Is it possible to Add a Favorite to a particular branch?
Another thing I couldn't find during my trial is the possibility to script Add a favorite to a particular branch automatically, so you can have a separate
"add files to favorites" and "add folders to favorites" and it would automatically put them in a files or folders branch.
That seems like an odd thing to think of and care about, enough to ask the forum, after your trial has ended. And after you said yesterday that you would only consider buying the product if two particular features were added.
To be blunt, I am a little suspicious that you're using a pirate version. I would hope that you wouldn't be rude enough to waste our time by doing that but it does seem like an odd question and we've had so many people asking questions in the forum who have, one way or another, outed themselves as pirates.
[quote="leo"]That seems like an odd thing to think of and care about, enough to ask the forum, after your trial has ended. And after you said yesterday that you would only consider buying the product if two particular features were added.
To be blunt, I am a little suspicious that you're using a pirate version. I would hope that you wouldn't be rude enough to waste our time by doing that but it does seem like an odd question and we've had so many people asking questions in the forum who have, one way or another, outed themselves as pirates.[/quote]
It may seem odd and suspicious, but I didn't want to feature request so many things at once since my trial has ended, and no I am not gonna risk my PC with pirated software, also since my workflow is based heavily on that context feature I asked for, there is little sense in using a pirated copy that wouldn't have that feature.
BTW I would immediately buy the product if those features were added, especially the context menu thing since that is my kinda workflow.
Actually, I was searching for something like this as well and I did pay for this awsome tool. What would be nice is a button, or a way in Favorites that does something like:
Go "D:\Documents\Customers" FOLDERCONTENT
The above command shows a branche of subfolders and contents. Clicking on a document opens the document, but clicking on a subfolder doesn't make the active listener to open that subfolder. What should be changed to achieve that?
Many thanks!
Daan
Use FOLDERCONTENT=button instead of just FOLDERCONTENT.
