Is it possible to make a dialog box for copy/move?
I was wondering if it's possible to make a dialog box for copy/move files? For example, it would work like this:
-Select the files you want to copy/move
-When you hit the copy/move button (or hotkey), a dialog box would open up
-Inside the dialog box, in would say "Copy (or Move) selected file from to
-There would be an option for Yes, No, Cancel
This would just be a confirmation dialog, to prevent any accidental moving. Also, would it be possible to have the current, destination directory editable inside the dialog box?
Are the custom button creation commands capable of doing this?
Thanks.
The closest possible thing I can think of is that you could make a button which pops up a dialog allowing you to choose the destination folder for the copy. You could then cancel that dialog if you don't want to copy the files.
I'd have to play around a bit to get it to work so let me know if that would be useful, else I won't waste both our time. :slight_smile:
Thanks for the suggestion. Please don't bother making a button just yet, I will give it a shot first. I actually have another question that I will make a new thread.
