Is the code for my custom buttons stored somewhere like Script AddIns is?
I like editing my Script AddIns in VS code. I would like to do that with buttons too, without the hassle of copy-pasting from vs code to the button dialog. I found a button folder but it seemed to be pre-defined buttons. I didn't see my custom buttons.
Where or the button codes stored? if they are user-editable.
Script Add-Ins are text files that you can edit in anything.
But most toolbar buttons are self-contained, and stored inside XML config files that it would not make sense to edit directly (outside of doing very specific things). Use the built-in editor for those.
Most buttons are also very simple, and just a few lines, if even more than one. For complex scripts, turning them into a Script Add-In can make things easier, and those can add commands which buttons can use to invoke parts of the script.
That has been my experience so far. Just wanted to make sure I wasn't missing something. Thanks
