If I have a large tree, I'd like to be able to click on a button and have it scroll to the 'favorites' node at the bottom of the tree and at least make it visible if not at the top.
I saw the command that put a list at top, but that's not exactly what I want.
And - somewhat on the same topic, it would be nice to be able to rename the text displayed next to the favorites from:
H:\FolderA\Tax Returns
to
Tax Returns (H:Folder A) so that they would be sorted by name?
If you're clicking a button why not make the button display the favorites list itself instead of having to move the mouse over to the tree afterwards? Then you can remove favorites from the tree completely and make it less cluttered.
Names:
You can name favorites whatever you want them to be via Preferences (Favorites -> Edit is a quick way to get there), and when creating new favorites (assuming your Add to Favorites menu item runs Favorites ADDDIALOG -- if your config was based on an old version of Opus it might still run Favorites ADD which won't ask you for a name).
