Is there a way to display the scripterror icon from a script without actually
triggering a unhandled exception to do so?
If I handle the exceptions myself then it won't show that icon, but sometimes
it would be preferable to be able to display a message in output AND notify
the user that an error has occured.
Such as when displaying a modified errormessage.
If not, can it be added?
Maybe an alternate DOpus.OutputError(message), or a property would be the way to go.
In case you thought of doing otherwise:
It may be preferable to leave the text color for the message as is.
I mean, red text usually means DO script crash.
If colorchange is needed, theres the undocumented (to my knowledge)
way the Say script does it.
