Is there a way to switch between Styles with the keyboard?
Yes, as the topic says, is there a way to assign keyoboard shortcuts that allow me to swith between lets say "Dual Horizontal" and "Explorer"?
I prefer to work with keyboard commands as much as possible, hence the question. :slight_smile:
You can create as many keyboard shortcuts as you like from the customize dialog. The command to change styles is: Prefs STYLE=Explorer. Change Explorer to the name of your style.
Thank you very much Steve! :slight_smile:
Earlier this day i tried to Customize the Keys but did not find the right command. I love DOpus more and more for every day! I have 53 days left on my trial, but dont see the need for it, ie the trial, anymore, i will buy DOpus today! :slight_smile:
The button editor dialog contains handy dropdowns which contain all commands and their arguments. It's often a useful way to find the exact format for a command.
By the way, if the style name contains a space, use quotes:
Prefs STYLE="Dual Vertical"
Might seem obvious but it trips a lot of people up so I thought I'd mention it.
[quote="leo"]By the way, if the style name contains a space, use quotes:
Might seem obvious but it trips a lot of people up so I thought I'd mention it.[/quote]
O.k, i renamed two styles becasue of this, IE Dual Vertical became Dual_Vertical. Thanks for the tip, i will rename them back to their original now.
