[Issue] Layout distortion with foldertree
Hi everybody,
I guess i have some kind of an issue when switching between v/h listers and closing a folder tree.
Let's assume i have somehow managed to get this layout (in which I can't move the right seperator correctly btw.):
I close the left folder tree:
And if I now switch the listers to be horizontal, i get this:
If I trigger the foldertree visibility once more (the menu-entry for switching foldertree visibility is greyed out in this state), the right foldertree dissappears and I get two new folder trees on the left.
It seems as if DO forget's about closing the right tree and assumes, trees aren't visible anymore.
So there's something weird going on, isn't it ?
If i remember correctly, a folder tree to the very right of the lister window, is very unusal, it looks kinda distorted as well, so i guess this might be worth an investigation.. ?!.. o)
Thanks,
have a nice weekend.. o)
Rob.
You get a folder tree on the right if you're in Dual Horizontal mode and only have the bottom (right) folder tree on. That's by design. (It's a little weird, but so is only having a folder tree for the bottom file display. :slight_smile:)
If you have a toolbar between the two file displays then the tree, in this state, mistakenly thinks part of the toolbar is above it and does not paint that area, leaving behind whatever was there. We'll fix that.
