I have a filetype-group with containers (dlc,...), when dbl-clicking, it opens texteditor instead of the program assigned in filetypes. When deactivating "open unregistered files with texteditor" in prefs it works.
Btw. it is long time ago I used this filetype, but it always had worked before. Containers are not assigned in Windows.
As said, it worked before. I have different filetype-groups, this one includes .dlc- and .ccf-extension. On dbl-click they always opened downloader, now text-editor opens.
Because that's what the option does. If the file is one where no filetype exists, and it looks like text data, then it'll be opened in a text editor if that option is turned on.
(Filetype groups are not filetypes, remember. The filetype still needs to exist for things to behave normally.)
Turn off the option, or create a file type, and the problem should be solved.
You can create a filetype in a few seconds in the filetype editor.
Sorry Leo, that's not true, I never regged e.g. .dlc and DO opened it correctly with filetype-group including extension .dlc! Same with other filetypes (mainly used by portable apps which filetypes are unknown to sys and they are configured not to register them).
Well, don't ask me why, for testing I reactivated unregged filetypes and now it works again. And as you can see in pic 2, .dlc is not registered.
...because I know what I've installed and it also works after fresh installs. I also use filetype-groups a lot on USB opening my prefered portable app without "contaminating" the foreign PC registering filetypes (sure, most filetypes are known by sys).
Nevertheless thanks.
Edit: Create a filetype-group, add any non-existing filetype like ".abcdef" and define a dbl-click-action. It will work.
