Hi, all! I think I have encounted a little bizzare problem.
Basically, i want to automate following process:
select a folder in current lister's tab,
open path in a new tab
paste whatever in clipboard (files or folders)
close this new tab
I tried to accomplish following code, which I think have the right logic, but there is one point that I found is not working as expected, that is currentTabPath is always the old tab's path, which prevent from proper pasting.
Any suggestions on how to modify? Thanks!
function OnClick(clickData)
var selectedItem = clickData.func.sourcetab.selected(0);
DOpus.output('selectedItem'+selectedItem)
var targetPath;
// Check if the selected item exists
if (selectedItem != null) {
// Check if it's a directory or file
if (selectedItem.is_dir) {
targetPath = selectedItem.realpath; // Use the directory path if it's a directory
DOpus.output('targetPath'+targetPath)
cmd.RunCommand('Go NEWTAB');
cmd.RunCommand('Go "' + targetPath + '"');
} else {
//targetPath = selectedItem.realpath.path; // Use the parent directory if it's a file
} else {
// If no selection, default to the current path
//targetPath = clickData.func.sourcetab.path;
//DOpus.delay(3000)
var currentTabPath = clickData.func.sourcetab.path;
DOpus.output('currentTabPath'+currentTabPath)
cmd.RunCommand('clipboard paste')
cmd.RunCommand('Go TABCLOSE PATH="' + targetPath + '"')
