I have absolutely no idea how Wallpaper Engine decides when to pause and when to play, nor why you would ask me that rather than the developers of Wallpaper Engine.
TLDR: Please read the bolded portions.
I wasn't asking you how WEngine decides to pause or play.
I have numerous rules to keep the wallpaper paused, yet they’ve been bypassed. Moreover, nobody else has ever reported this happening on WEngine’s forum and they have a lot of users. This makes me suspect there may be something unusual about what DOpus is doing in this specific situation.
When I went to WEngine’s forum, there were tons of posts about momentary glitches, but they involved the wallpaper pausing while it was supposed to be playing—the opposite of my problem. There was only a single post where WEngine played for a spit second, which mirrors my situation. It occurred when Nvidia ShowPlay or Process Explorer was used. Like me, the poster used WEngine rules to stop the animated wallpaper that didn’t work. There was no published resolution to that thread. I also found another post, stating that state-change causes are not recorded by WEngine logs, which makes this even harder.
Given the likely difficulty and its specific nature with Dopus, before posting on Wallpaper Engine’s forum, I wanted to collect as much info as possible about Dopus is doing at the exact moment of the glitch. I’m not asking you to disagnose WEngine—I’m hoping you could provide any clues/info on what Dopus is doing differently in these 2 situations.
In one, Dopus renders a default folder. In the other, Dopus restores/renders a saved formatted folder. The glitch only occurs with the latter. I suspect restoring a formatted folder causes some additional Windows/window/rendering activity. If you could tell me what that is, that would be great.
If helpful, these are the three possibilities I'm most curious about:
Does restoring the formatted folder create/recreate any HWNDs, child windows, or rendering surfaces that aren't created when displaying the default folder—or temporarily change a window's visibility, size, Z-order, or activation state?
Does restoring that view invoke any external component, such as a shell extension, thumbnail handler, preview handler, codec, or separate process, that isn't invoked in the default-folder case?
Is there a DOpus debug/logging option—or a particular Windows diagnostic tool/event you would recommend—that would let me compare exactly what DOpus is doing during the two scenarios?
I'm not assuming any of those is the cause. I'm just trying to gather enough Dopus-side information to give the WEngine developers a useful starting point.
