My question is that if Directory Opus 8 has Mirror Browse??, so I can navigate in one Lister and the location changes in the other Lister too...
I think this is an important feature and I dont find it.... Thanks for your help...
This is called Navigation Lock in Opus.
The option to turn it on is missing from the default menus (as far as I can see), but you can add it by selecting Settings -> Customize, changing to the Commands tab and the Go category and then dragging Navigation Lock to where you want it on a toolbar or menu (or hotkey or context menu).
